Can somebody help me solve this physics problem?
neonerd
As much as i hoped and thought i knew, i'm kind of stumped with this one:
A 65.0-kg man is about to run across an icy pond. The coefficient of static friction between his shoes and the ice is 0.160. What is his maximum possible acceleration?
Can anybody tell me how to do this? not just the anwer, i'd like to know the process as well. thx.
I love physics..even though I dont remeber any more how to solve any of the problems, I still enjoy reading about the solutins...
Originally posted by: Anubis
find the normal force multiply that by the coeff of friction to get force of friction plug that into F=ma, solve for a
The frictional F is constant (as above). No other F is mentioned, but theoretically an infinite force could cause him to have infinite acceleration.
Do they mean the deceleration with no other applied forces?
To be honest with you, it's been wayyy to long since I did problems like that. I don't even approach that in high school physics... that's about 3rd year college stuff. Not extremely difficult, but definitely a pita if I wanted to skim through notes and type a solution.
the symbol (Del, upside down triangle) is the gradiant thats what i thought he was refering to i know thats a curl
heh.. I figured you knew what you were talking about. Your solution uses curl equations to solve it and you actually states 'curl equations'.
