Can Power Supply Unit damage system?
viotrex
Recently I bought a Maxtor Diamond Plus 30GB hdd. But I have had it changed for the 3rd time already. Some of my friends told me it could be the power supply unit that's at fault. And some of them told me that it could be heat problems due to the fact that it's running at 7200 RPM. I am getting quite frustrated here as the technicians over at Maxtor can't tell me what's the problem as well.
And I can't distinguished whether my PSU is APPROVED or NOT APPROVED. Please tell me how do I check whether it's Approved or not. And whether a PSU really have that huge impact on my system and hdd. Cause I was thinking, logically, if the PSU can damaged the hdd due to voltage fluctuation, then shouldn't my Celeron ship get fried first? since CPU is more heat and voltage sensitive.
I appreciate any help that I CAN get.
Thanks alot.
WHipLAsh13
1,719
Go here to get a list of approved athlon power supplies. The power supply could possibly damage your hard drive but you are right in that it would also damage other peripherals also. Have you tried installing a utlility like Sisoft's Sandra to check your case temperature. Maybe you need more air circulation.
John
Moderator Emeritus<br>Elite Member
Valhalla1 had 3 or more HDD's die on him until I suggested a powersupply replacement. Maybe a coincidence?
viotrex
Thanks for the swift response guys regarding my PSU problems, but I am not using AMD but using Intel /b Celeron /b. So is there also a list of approved power supply units for Intel based system? I am quite desperate to get a good and reliable power supply, cause as I am typing this, I can hear my hdd having those funny noises again.
Celeron 566 o/c 994MHz /w 117FSB (Using own cooling system)
Abit BX6r2 Slot 1 Mainboard
Crucial PC-133 CL2 256MB SDRAM
Crucial PC-133 CL2 128MB SDRAM
Samsung 753DF 17" Flat SCreen Monitor
Inno3d KYRO II 4500 32MB SDRAM
Seagate U5 20.4GB ATA-100
Maxtor Diamond Plus 30GB ATA-100 7200 RPM
Hercules 7.1.1.4 drivers
Mitsumi 48X CDROM
LinkySys 10/100 BaseT Ethernet Card
Creative SB Live! Gold Edition
Creative FPS 2000 Digital
