I just put together my new system for college and would like to connect it to my cable modem to finish installing software (instead of downloading on the other computer and burning CDs) but when I try using the new one, the connection remains active for about 10 seconds. After that, nothing works although the connection icon says the cable is still plugged in.
Both computers are running WindowsXP Pro.
I'm using a Netgear NIC in the older system and the onboard NIC on the Abit AT7 motherboard in the new one. Both are set up exactly the same. I turn off all 3 items. Give power to the modem and let it sync up with the cable and then I turn on the new system. I can almost load anandtech.com before it just stops loading. Going to any other site gives me a no server found error.
Any ideas? Any settings that I'm missing?
