can not find CPU FAN !!!
compguy786
2,141
Guys,
I have this HP slimline PC, the CPU fan has died. It has a 4 pin connector, and
is very small. The Delta Electronics model is - AFC0712DD
I am trying to find something small, and with 4 pin that could fit and work
please help !
aigomorla
21,136
3,674
Originally posted by: compguy786
Guys,
please help !
so im assuming its not a standard PWM, can you possibly take a picture of this header?
Beanie46
527
To help, I found someone on HK's ebay site selling this exact fan..........
http://cgi.ebay.com.hk/ws/eBay...PrinterFriendly=1&pv=1
The fan is a 70mm x 15(?)mm......4-wire, so may be some sort of PWM.
Closest thing I could find was a Delta AFC0712DB-5DES at Alan Computech Int'l.
http://www.alancomputech.com/afc0712db-5des.html
Or, from the same place, a Delta AFB0712HHB-5N78.
http://www.alancomputech.com/afb0712hhb-5n78.html
Searched Delta's site for the fan and got no results.....the original fan mentioned by the OP may be an HP specially ordered/configured fan for their particular application and not regular stock by Delta.
Zepper
18,998
This page at jab-tech has two 70x15 fans with PWM (Cooljag, Delta) and the Delta unit might be a close match: http://www.jab-tech.com/70mm-Fans-c-237.html . Another place you might look is thermalfx.com which generally has a good selection of fans. Newegg also has had the Evercool 70x25mm model. It's not PWM, but you can get more flow for less noise if you have the room for its extra thickness. Non-PWM fans will work in your application. Other places may have the 70x25 at a lower cost than the Egg unless you're buying other stuff along with it to help spread the ship cost. The Startech 70x25 on the egg is probably the Evercool unit, rebadged and at twice the price (typical of Startech products - just rebadged generics at two to three times the price)... The model no. of the Evercool 70x25 is EC7025M12CA to ease your search. Had three hits on froogle. It has worked well on my sock-A Duron 1800 running at about 2000-2500 RPM on a fan controller. Yup, the pic of the Startech on the Egg is identical to how my Evercool spare looks.
I also found one Everflow on fleabay with the PWM. About $8.00 BIN. searched on- 70x70x15mm fan -.
.bh.
