Just wondering if non K Haswell's work the same way as SB/IB i5's and i7's where you can still overclock them by 4 bins, up to their max turbo frequency? A friend of mine is looking towards a new build and with the limited OC headroom Haswell provides, I'm think he might be better off with the non K, which has a more full featured instruction set than the K's. If I can OC it up to it's turbo frequency, the difference between it and a K series would only be another 3-400 MHz if I'm to keep temps in check using air cooling.
Thoughts?
Thoughts?
