Can I use a wet saw (tile) without water?
Arkitech
8,356
4
I need to cut a few pieces of slate tile but I would prefer to do it dry than wet. I've tried cutting the slate with the blade being wet, but the dust from the slate turns to almost a clay like substance and it gums up the saw. Would I damage the saw if I cut the slate dry?
Nik
16,101
You don't just get it wet. You have to have a stream of water meant to cool the blade and wash away the dust.
I'm pretty sure you need water with a wet blade unless you're trying to overheat and warp the blade.
Raduque
13,140
138
Well, according to wikipedia:
For larger jobs an electric tile saw or wet saw is used; this saw is similar to a small mitre saw except that water is distributed on the saw blade to lessen the effects of heat and friction.
You could probably do a couple small pieces, but if you end up cutting lots, I'd probably just deal with the dust gumming up, otherwise you could damage the blade.
drnickriviera
2,456
266
You need a blade made to cut dry. If you are getting clay, you need more water. Get a water hose on it.
BoomerD
66,279
14,699
I doubt the blade would last long without water. The water cools and lubricates the abrasive blade.
There may be a special dry blade for that, otherwise, use more water.
SphinxnihpS
8,368
25
I have an MK Diamond wet saw that goes through about a gallon of water every five minutes. How much water are you using? I can not imagine "gumming up the blade" with anything but way too little water.
Also, if you want more dust, cut dry. It's a special blade, and it probably won't fin in a wet saw.
disappoint
10,132
382
Set up a pressure washer aimed at the blade where it gets gummed up the most? Lower the pressure if possible so it's not too overpowering. I've never tried this so do so at your own risk.
GuitarDaddy
11,465
No, will ruin you blade in a hurry. Use more water, the bottom of the blade should be submerged in water. Wear an apron because if your doing it right its a nasty job with water flying everywhere and you will be soaked in no time flat
Homerboy
30,890
5,001
just take a garden hose and put it on a trickle over the piece you are cutting.
You DEFINITELY need water though
DrPizza
Mar 5, 2001
49,601
167
111
www.slatebrookfarm.com
RTFM! (Read the manual)
If your blade is gumming up, you don't have enough water in it. Also, they do make dry blades that you can put in a circular saw. You do NOT want to do this indoors. I had tiled my backsplash after I ordered a built in microwave. Bastards who wrote the dimensions had something and 3/16". Actual was something and 3/8". I had left 1/8" gap between the top of the tile & where the microwave would be. Unfortunately, that left 1/16" too small of a space. That one cut, the width of the microwave, created more dust than all of the dry wall sanding in that room.
vi edit
62,484
8,345
Take an old water bottle, fill it up with water and punch a nail hole near the bottom. Sit it near the blade and let it squirt out on on your cutting surface.
feralkid
16,860
4,972
Why?
LittleNemoNES
4,142
As a former construction worker, you really should just use the water to minimize dust and avoid overheating the machine.
13,804
I would just do it properly and use the water as intended. There are dry cut saws, which is basically a blade that goes across a couple times then snaps the tile in two, but I think those are made more for the small bathroom tiles.
SphinxnihpS
8,368
25
There are dry cut saws, but they are for outdoor use, and for use on generally softer, less dense materials like pavers and bricks. The blades are similar, but have slots and sometimes dimples in them to help them cool; wet saw blades do not. Most tiles are also made of very hard porcelain, which does not lend itself well to dry cutting. It is impossible to use too much water while wet sawing.
Fritzo
41,920
2,161
DON'T DO IT. The heat generated will most likely snap the tile and could fracture the blade. This happened to my dad a long time ago...burned his arm to hell.
Fritzo
41,920
2,161
Spam post and link deleted.
LOL- my neighbor caught a drop cloth on fire by cutting ties without water :D Still give him crap about that. He didn't know you needed to put water in the saw...he thought "wet saw" meant you could cut wet things :tearsofjoy:
Also...
Reactions: johncarry
