Can I use a 4 ohm 6x9" speaker, and an 8 ohm 6x9" speaker at the same time?
Accipiter22
Banned
Feb 11, 2005
7,942
OK, I have 2 6x9" Polk EX speakers, they're at 4 ohms.....I need to fix one of them, or get it fixed. In the meantime can I put one of the stock 6x9s back in, even though they're 8 Ohm?
Qacer
2,721
You should be fine. Although, your 8-ohm speaker might sound less powerful than your 4-ohm one, but then again, if you are really pumping up the volume, there's a point where you'll be hard at telling a difference with the sound. The 8-ohm and 4-ohm impedance rating are their to guide you in terms of how much power your amplifier can handle. Normally, the lower your impedance rating, the more current your speaker draws. This would translate to a higher power requirement, which may be too much for your amplifier.
Eli
Super Moderator | Elite Member
8
You aren't going to let the smoke out of anything, if thats what you're asking.
