Can I use 8-pin PCI-E in 6-pin connector?
kamel
78
I currently have a 2900XT, which uses the 6 and 8 pin connectors. Since I have everything neatly routed behind my mobo, it is quite a chore to replace cables. Can I just use the current 8 pin in the 6 pin slot on my 4870?
Thanks.
ViRGE
Elite Member, Moderator Emeritus
167
Yes. Although depending on how the connector on the cable is designed, it may be difficult to use it if the extra 2 pins can't be broken away.
