Can I use 2 access points for 1 connection?
machintos
1,652
Okay, so I currently have a linksys B access point and I'm thinking about getting a D-Link G access point. Can I use the two togehter? I guess the connection will be something like wall phoine jack -> dsl modem -> G access point which will connect to both the computer and B access point.
ScottMac
Moderator<br>Networking<br>Elite member
Mar 19, 2001
5,471
One computer to two APs?
No.
You can't.
Two APs to the same wired connection?
Yes, if you set it up right. *But* any one client will only connect to a single AP.
One device acting as a repeater and AP?
Not likely with consumer-grade stuff.
Scott
machintos
1,652
No.
You can't.
Scott
Yes, what I meant was two APs to the same wired connection wo I have both the B and G network at home.
For the heck of it, I'm just gonna try connecting them and see what happens. I'll update later.
