Can I save web page articles? Best way w/ images...
taltos1
892
Hello,
I read a lot of articles online and would like a way to save them for reference later on. Right now I simply print them or copy and paste into Word. I would like to save the text, images(embedded), and keep any links working? Is there anything that can accomplish this?
Thanks a lot
ForumMaster
7,792
well with opera, you can do save as and select HTML file with images and it works pretty well.
91TTZ
14,374
There are also utilities that will save not only the page you're looking at, but the contents of the links on that page to a specified number of levels.
compnovice
3,192
yup.. these offline browsers come in pretty useful, if you travel a lot or have flaky internet connection. I don't know of a free one, but surely a search should reveal some...
RossMAN
Grand Nagus
Feb 24, 2000
78,927
389
Or if you're using the inferior FireFox check out Scrapbook.
taltos1
892
All excellent suggestions, thank you. But to take this one step further, is there a way to save a web page as a single document with all the text, images (embedded) and links working.
The Firefox save as works great, but it creates a HTML file plus a folder with the images...
yllus
Elite Member & Lifer
Aug 20, 2000
20,577
432
I like to print to an Adobe Acrobat file myself. Saves absolutely everything, but it does kill links.
Auric
9,591
I have done this frequently since IE introduced MHT in ye olden days however it no longer works with eBay (natch!).
