I am thinking about buying my friends geforce 6800. Will i be able to run it on a 350 watt power supply? I had it running for about 4 hours with no problems. Will it cuase any problems if I run it long term?
It depends on what the rest of the computer amounts to. If it's just a basic system with a quality 350w power supply you might be able to get away with it.
