Can i replace the subwoofer in my Creative Inspire 5.1 system?
niwi7
1,095
I like the sattelite speakers but i want much more of a bang out of the subwoofer....is there any way i can replace either the speaker in the box or get a whole new woofer but it needs to have all the plugs for all the speakers...u no wut i mean....also there is an unused yellow wire saying subwoofer on it can i plug that into a diff sub? if so which sub takes a regular headfone jack-type plug?
ElFenix
102,402
8,574
you could replace the driver... you might even be able to replace the amp but you'll probably do best with a more efficient driver from partsexpress.com
niwi7
1,095
whats a driver? which 1 should i look for? its a sub not a driver....unless a driver is another word for subwoofer or something
semi-new to this soooo excuse the n000b ness
Agamar
I have the inspire 5.1, and I really don't think you will get much more bass out of that encloser. I found that putting under my desk helped a lot. If you really want something bigger, you are going to probably need to get a real system and hook it up to your PC.
