- Jul 10, 2005
- 1,053
- 0
- 0
Originally posted by: RiDE
...or you can just unplug it for 5 seconds.
Originally posted by: entropy1982
blah i dunno where it is... and my p180 has SO many wires in it lol where woudl the motherboardchipset fan plug into anyway?
Originally posted by: Ken90630
Um, am I missing something here, or couldn't you just look at the chipset fan on your mobo, look at the very short wire coming off the fan, and follow it to its header on the mobo? The header should be within in an inch or so of the fan. I'm not trying to be sarcarstic -- that's really all you need to do (I'd think). Oh, and unplug it before you power up. Connecting & disconnecting mobo connectors with power on is not the best of ideas.
BTW, if you do identify that fan as the culprit, Zalman makes some really nice passive chipset coolers. A nice heatsink on there instead of a fan would mean never having to deal with this again.(I assume you're referring to the northbridge fan on your mobo? If you're referring to the CPU fan, I assume you know to NOT unplug that even for a second with power on.)
Dude if you cant figure that out by yourself, HTF did you build yourself a system ???. :roll:
you can turn on the computer without a heatsink for a little over a second, so you can definitely run it for 10-15 seconds without a fan, maybe longer. some heatsinks dont even need a fan for processors up to an x2 4400+! the scythe ninja comes to mind...i own one and can backup this claim.
Depends on the CPU & cooler. I would respectfully challenge your claim that one could "definitely run it for 10-15 seconds without a fan, maybe longer ...." I saw a picture somewhere awhile back of an utterly incinerated Pentium, and the caption said something to the effect of the guy having forgotten to plug in his CPU fan and "in less than 10 seconds, this was the result." I can still see that picture in my head. And since the OP doesn't have a Scythe Ninja, I'll stand by my generalized recommendation.
I personally would recommend swapping out a suspected-bad CPU fan with another fan as a way of isolating it as a culprit, rather than unplugging it entirely, but that's just me. Or just unplug the northbridge fan (if there is one), and if the offending noise is still there, it's the CPU fan (or, I suppose, a case fan). Again, though, it depends on the CPU & cooler. I don't doubt there are some CPUs that could survive 10 seconds or more with just a heatsink on them, given the right heatsink. Just seems to me that chancing it could prove expensive. :Q
For discussion purposes, we both know that many modern CPUs have auto-shutdown anyway if the temp gets too hot, but it's not real good for the chip to get that hot even once.
I think he was referring to a northbridge fan anyway, so the issue is more or less moot.![]()
hehe... i never looked inside before asking sorry... the wire is right by the fan =P... culprit was actually this ( http://www.newegg.com/Product/Product.asp?Item=N82E16821104104 ) piece of garbage.... it was making this "clicking" sound over and over and over... would newegg give me my money back or am i SOOL?
now that i unplugged the disc drive.... i can't see my PATA drive anymore... weird... good thing i don't really need it =P ... anyone know what it could be tho? the only thing i changed was uplugging this disc drive from the floppy cable (then i tried uplugging the cable from the mobo) and the usb cable (required to be plugged into the mobo for it to read the difft types of cards).
thanks
sorry for the newbness before =P
All of you debating how long a CPU will last without a fan know that the poster was talking about disconnecting his chipset fan, and not the CPU fan, right?
Also, most of the time if you have a well ventilated case you don't actually need the chipset fan. A passive heatsink should work just fine.
yes, we knew.
i understand what you are saying and ive seen that picture, but i dont think that happened in less than 10 seconds. if it did, it was because the guy either didnt mount the heatsink right, didnt use thermal compound, or a combo of the two. copper and aluminum both have a high enough heat capacitance to keep a processor from cooking itself for 10 seconds.
Who knows ... I just remember the caption. I think it also said something like "Don't try this at home, boys & girls." Presumably the guy didn't time it with a stopwatch -- in order to do that, he obviously would have had to know his fan was unplugged, and he obviously didn't! :laugh: Expensive mistake. :Q Actually, I've seen several such pictures over the last few years, and I just don't remember exactly where I saw this one. I think it was online, but it might have been in a computer magazine. I might have saved a screenshot of it or something; I'll PM you with it if I ever run across it again.
If memory serves, I think it was an early P4, if that matters. But I'm not 100% certain. Shifting gears slightly: Which stock coolers do you think are better -- AMD's or Intel's? I don't use AMD's stock coolers 'cuz I think they're too noisy, but I don't have any personal experience with Intel's.
