Is it possible to hook up my case fans to a thermal switch of some sort?
I want to be able to have the fans turn on only when the temperature reaches a certain degree and then turn off after operating for a set amount of time or until the temperature drops down. Kinda like the way a thermostat controls a home a/c system.
In case you're wondering, the reason behind this question is simply that I don't want my 2 x 108 cfm fans running all the time since they're so loud. I only want them on when they are needed due to excessive heat. I have 2 x 30 cfm fans for normal case cooling.
-CamaroGuy
-CamaroGuy
