Hi all,
So I want a physical temp reading on my new machine - I plan to go watercooling on a new Sandy Bridge system, and I'd like to know of any temp out of range from a reliable bit of hardware rather than software monitoring. Also I want to keep an eye on the GPU. BUT... I still want my motherboard to control the fans - it's a new Gigabyte rated to nearly 2A on each header so it's fine on that front (120mm all round), and it also does a great job of keeping it quiet, which is obviously good.
Questions...
1) Can I get such a device? Fan speed and temp monitoring hardware but leaving the mobo to control them?
2) Or is this a bad idea anyway, since when I go water and start overclocking for real, I may want to manually turn up the fans? Or maybe it's a bad idea because the average fan controller might be just as good at monitoring temps/setting speeds as a mobo these days?
Thanks!
/edit... brainwave... anyone ever tried splitting the signal cable (the third one) on a fan, then running one wire to a fan controller, and one to the mobo? Same wire just split and soldered. That way the mobo controls speed/PWM, and the hardware controller still gets data from the fan?
Questions...
Thanks!
