Can I get a little help here? Or Ut problems connecting to a network
themightyplatypus
Whenever I try to play UT online I get an error. Can someone please tell me what the F#$K this is
Tiny Personal Firewall has detected that application c:\WiNNT\System 32\LSASS.EXE' was replaced by another application with description LSA shell (Export Version) . Do you want to accept replacement of this application? Yes/No
OS windows Xp
John -
Can't help you with UT, but you might want to change your thread title to "UT problems connecting to network" or something like that so people will know what the thread is. Little vauge on the title.
See ya on Thursday!
EtOH
You have Tiny Personal Firewall installed and it detected a replacement of your 'LSASS.EXE' program. Whenever you replace an executable on your computer that access anything network related, Tiny Personal Firewall detects this and asks if you want to accept the replacement. See if this is part of your UT install. If it is just click yes and this shouldn't show up anymore. As long as this isn't a Trojan (which is a virus type program that gives hacker access to your computer), clicking yes should let you continue normally.
Psyber
