- Jun 13, 2013
- 4
- 0
- 0
Hi there I have a cooler master scout case and I see the gtx 780 is a large card I'm wondering if anyone can help me find out if I can fit that card on the case?
Thanks in advance
Thanks in advance
What is the maximum length graphics card supported?
The CM Storm Scout is designed with portability in mind. It can accommodate the largest 280GTX or HD 4870 X2 type cards. This includes all GPU 10.5" or 267mm in length or shorter. GPU cards have a maximum clearance for 10.6" or 270mm maximum length inside the Scout.
GTX 780 Graphics Card Dimensions:
4.376 inchesHeight
10.5 inchesLength
Dual-slot
Man thank for all your input this has been good information. Next week it should be arrivingand iI can't wait to finally put crysis 3 and metro where they belong lol
Thanks
