- May 23, 2002
- 16,928
- 8
- 81
So most BluRay player have the USB port in them where you can connect a flash drive. I assume I could also use that to connect an actual external HDD. However, do they put out enough power to actually make the USB HDD work since it only has 1 port and not 2?
Assuming the answer is No, would it work to get a powered USB hub, connect that to the BR player and then just plug the HDD into the hub? Otherwise I guess I'd have to get an actual HDD that had its own power supply with it and not the double USB connection?
Thanks.
Thanks.
