Can I connect a PS2 to my TV Tuner card?
Imported
14,679
23
Or do I need the VGA adapter for the PS2? Anyone do it before?
It's the Leadtek TV tuner..
HendrixFan
4,646
Yes, Ive done it before. Just get the right cables to run the video and audio into the TV Tuner (I used the ATI AIW), and just open up the viewer. The resolution isnt that good, and it will be much more noticable on your monitor than your TV.
Strangely enough, I was just mulling over whether or not to get a PS2 just for NCAA2003, and hooking it up to my TV Tuner.
Dragnov
6,878
Yes. You'll need some cables though that will run you a few dollars though. I have my Gamecube hooked up to my computer.
Video in is automatic (same plug) and then you just gotta get the two RCA female to one mini stereo in, and put it into your audio in on your sound card.
