...I'd go B85 + G3220 as a minimum for a basic build that has some balls and some expansion. It will be more like $350...
Yes but you're probably better off buying a prebuilt.
Now that's an amazing bottom scraper! The last single core CPU still for sale on Newegg.
It will work kinda like an 8 year old computer in a lot of ways, but will be new.
Just thought I'd check to see if it's even possible to build something reasonable for $300. Turns out it is, but its the cheapest possible components. Even then I properly overspent a bit on the mainboard.
Sempron 3850
ASUS AM1M-A
El Cheapo Kingston RAM, 4GB
Kingston SSD V300; 120GB
Cheapest case with PSU I could find (Likely crap PSU, but at this level of power-draw it should work fine)
Total: $220.95 without Windows. If you feel it needs more CPU grunt, add an Athlon 5150 or 5350 if required.
It is faster but does the budget need to stay under 300? Is windows 7 better for her then 8.1? Will she notice the speed difference with what she is doing?
She probably won't notice speed difference, but at $300 he needs to get her the best computer at that price
I am still thinking this is the best bang for the buck...
http://www.amazon.com/Dell-i3647-123...productDetails
I almost bought that one for my inlaws in lieu of building one. For the price it's pretty hard to beat for a glorified browser. I'm very fond of the new Pentium and specifically the G3220. All the rest of it is just a matter of component selection... i.e. the 500GB HDD and 4GB RAM.
I think you found your solution.
Note: If you live near a MicroCenter, you can probably get that even cheaper, or something similar.
