- Oct 13, 1999
- 22,377
- 7
- 81
My wife's system is running an Antec Phantom 350W PSU. It's a fanless unit. Her Lian Li case has an 80mm blowhole and I had installed an Arctic Cooling 3TC, an 80mm temperature controlled fan. Since temperatures have risen lately that fan has been spinning like crazy after the system's been on for a while.
My theory is that if I used a PSU with a quiet 120mm fan, the 80mm fan would not have as much reason to spin up, and thus overall noise will be lower plus perhaps overall temperatures may be lower - the other reason... her system locks up when room temperatures go past mid-70s.
I just received a Seasonic S12 380W that I ordered from CensusPC. It's the older revision since it doesn't have the PCI-E plug (now I have to go find my adaptor) but I've heard the older revision is quieter than newer one since the fan doesn't spin up as aggressively.
I'm going to install it this afternoon and will know by evening if system is quieter. As for lockups... we'll see.
