Realistically you'll be just fine and they don't interfere with each other. Twisted pair and electrical can be run right next to each other with zero problem (there's a reason it's twisted). Same with speaker cables.
I however don't like running low-level interconnect near power.
Not true. Especially with speaker wire.
Parallel runs should be at least 3' apart. You can cross directly if you have to. All the low voltage stuff can run parallel to each other but never mix your romex with your data/AV stuff.
EIA/TIA says it's just fine unless it's high voltage and then requires like 18inches IIRC.
Standard practice is to run them apart from each other.
Standard practice is to run them apart from each other. Residential norms are 3'. I can't tell you how many times I've been in a house with a 60Hz hum or wonky data runs... when you flip the breaker on the circuit that the wire was run too close to... wow. Problem solved.
<-- 15 years of high-end home automation.
<-- 20 years of AV sales and system design.
no.
edit - it's against code, and wouldn't work very well either. you really don't want to have signal/low volt cables running parallel with power (in close proximity).
First, no, I wouldn't do this, at least with anything related to a sound system, speaker wires, etc. However, as far as I'm aware, there's nothing in the NEC that says it's against code. In fact, the NEC specifically says it's not against code: page 543, 300.4 (text under diagram): "Signal and alarm wiring is run through the same stud holes as the NM cables. The NEC does not prohibit use of more than one cable through a single hole." Further, here's an illustration from Mike Holt: http://www.mikeholt.com/onlinetraining/page_images/1008708852_2.gif
In fact, as far as I can tell (I was researching this the other day), there's no minimum distance required in residential for water lines & NM-B. (I'm running water and electric out to my garage & the lines will have to run parallel to each other, about 4 inches apart, for 6 feet.)
Incidentally, I'm putting in a 100Amp breaker panel in the garage. The garage is attached to the house. Does anyone know if I'm required to run a separate ground to a grounding rod? Or is connecting it to the ground on the main breaker panel sufficient?
EMI usually isn't a big deal in most homes.:biggrin: @ unbalanced home audio.![]()
