lokiju
My house is wired with cat5e and I cannot for the life of me get anything over 100mb/s out of it.
I wish I had some extra length so I could cut a piece and make a patch out of it and see what that does, but I don't.
It seems hard to believe that something like a RJ45 connector or wall jack would cause this, but maybe I'm wrong.
To give some more detail, here's exactly what my set up is.
In my living room I have a gig switch, from that I have a flat cat6 that runs under my carpet to the jack behind my couch. When I plug this flat cat6 into my laptop to test I'm getting gig. Then I plug that into the cat5e which is interfaced via a wall jack that came with the house. This runs to my garage where there's a junction box. When I plug it in from the cable in the garage in that box I only get 100mb/s.
The cable is 100% cat5e rated so now I'm wondering wtf is causing this. The only things I can think are the issue is either the connector on the wall jack, the RJ45 connector on the end that's in the junction box in the garage or some rating or noise issue with the cable somewhere between the living room and the garage.
I wish I could just use the cable that's in there now as a pull string and pull some new cat6 but the builders stapled the cable all along the way to the wall studs, so that's not an option.
Example of what I mean when I saw wall connector.
http://base1.googlehosted.com/base_...es/29/2944_300.jpg&size=20&dhm=9cd77936&hl=en
So any chance that a RJ45 wall connector could be to blame?
