can anyone help me with this math problem?
DoNotDisturb
842
i'm like totally stuck... any hints? don't give me the answer
Find tangent lines to curve x / (x+1) that pass through points (1,2).
At which points do these tangent lines touch the curve?
"given hints:"
1. use quotient rule
2. we have points, use point-slope formula
3. two answers
WHOOPS CHANGED the EQUATION
MacBaine
Banned
Aug 23, 2001
9,999
take the derivative and you get that the tan line has a slope of -(1/2). you can do the rest.
Edit: Oops, it's -1/4
Edit: ok, let's try again with your new formula.
DoNotDisturb
842
well i took the derivative, i got x+1-x^2 / x^2+2x+1
do i substitute that for "m" in the pointslope formula, hence then i would have:
y -2 = x+1-x^2 / x^2+2x+1 (x - 1)
thats the farthest i've worked, but for some reason i'm stuck, i then speculated, therefore i'm posting to see if i made any errors.
DoNotDisturb
842
sorry, typo in the equation above, thats the equation i'm trying to work with, any mistake i've made?
MacBaine
Banned
Aug 23, 2001
9,999
"given hints:"
3. two answers
y = x(x+1)^-1
y^1 = x[-(x+1)^-2]+1(x+1)^-1
= m
use this to find an equation for the line. plug in 1 for X to get the slope.
= 1/4
then plug in x and y to find an equation. y-2=1/4(x-1)
y=(1/4)x+(7/4)
I dont know how you'd get 2 answers. I used multiplication rule instead of quotient... but this should give you a start.
RossGr
3,383
Here is my solution for this. I did not check my results, so you need to do that. I believe that this will get you were you need to go.
hamburglar
2,431
why do people put things in pdf format?
RossGr
3,383
Because most everybody has access to acrobat reader, while many may not have MS Word installed. It is just a nice universal format.
DoNotDisturb
842
anyone have the idea on how i get the points? do i just use my calc and find all the points of tangency?
