Can anyone help me with a flooring repair question?
iamwiz82
30,772
13
http://www.infinitemile.com/gallery/misc/IMG_2337?full=1
The problem I discovered upon pulling up the carpet was that the 3/8" plywood above the 1"x6" subfloor planks was rotten in on corner of the room. I am in the process of cuting it out, however I'm at a loss as to how to cut the last 4-5" nearest the wall. I cannot get my reciprocating saw close enough and I don't have another way of cutting only 3/8" worth of plywood without chewing up the planks below.
What am I missing?
BTW, notice the beautiful green and grey linoleum? Yuck...
EDIT: Success! First I tried my reciprocating saw, but that was making a mess of the surrounding plywood, I then tried a pull saw, but that was slow and now too great close to the wall, but then the lightbulb over my head went off! Dremel! Finished in in no time.
I've replaced about 4 feet of plywood so far, need to cut down two more pieces and I'll be done with the repairs and I can then lay the new floor and fill in the gap between the wall and the floor with some insulation or perhaps foam spray, then install the quarter round molding and she'll be done :p
iamwiz82
30,772
13
Originally posted by: dartworth
that is not a reciprocating saw...
No, that's a circular saw. There is more to the room than just those few square feet you see. ;)
D1gger
5,411
What am I missing?
I would use a Sawsall.
ManyBeers
2,519
What am I missing?
Get a good sharp chisel and have at it. It will do the job. Or you could remove the baseboard and use your Sawzall and cut it with that.
dartworth
15,200
10
why do you have to cut it?
I would remove the molding off the wall first, then use a wonder bar and start prying. Pry up as much as you can/want and cut/snap it off.
I went through the same thing in my kitchen. We ended up having to pull out a few hundred staples...
iamwiz82
30,772
13
What am I missing?
I usually get kind of... uhh... overzealous with my reciprocating saw. I'm trying not to destroy those plank :p. The chisel idea is probably the way I will go.
ON a side note, I'm amazed at how good the original floor is. it's coming up on 60 years old and the wood is in great condition.
iamwiz82
30,772
13
Because the plywood is only rotten about 1/3 of it's total distance, so I'm only removing that portion.
dartworth
15,200
10
For some reason, I thought you were going to finish the flooring under the plywood...
What kind of flooring are you going to put down?
iamwiz82
30,772
13
No, I'm going to leave the plywood since it is even with the rest of the house. I'm putting laminate over top.
dartworth
15,200
10
seems like a lot of unnecessary work...
anyways...take the baseboard off,cut the ends where you are into "good" wood and then it should just pry up.....if you hit the subfloor...it won't hurt anything.
Ornery
17
Hope you found the source of that moisture!
Remove the baseboard, and use a "Sawzall" with 12" (flexible) blade. Cut it along the wall with the saw horizontal to the floor.
iamwiz82
30,772
13
Whatever it was happened long ago. I'm assuming that it was a leak in the roof/ice dam, since that's an exterior wall. Never did any damage to the 1"x6" boards though. Thank goodness for the ugly linoleum :p.
DrPizza
Mar 5, 2001
49,601
167
111
www.slatebrookfarm.com
How about spending 5 minutes with a utility knife?
I've done that before, rather than spend 20 minutes trying to figure out how to do it with the available power tools.
iamwiz82
30,772
13
Ornery
17
I'm guessing you don't have a variable speed trigger on that "Sawzall". That will be the day I use a Dremel for any serious work, let alone a substitute for my recipricating saw!
