A few weeks ago before I went to Europe my computer wouldn't find the EIDE drive upon bootup. I would turn it off and then restart, but the same old thing would keep happening. Once in a while it would get into windows. I could use it once iin a while. Once it got going it was fine for the most part, but then I would shut down for the night and the next day it wouldn't work. Well, one time while it was working I reformatted the hard drive and then installed windows XP figuring at least I could see if it was a software problem since I was running the same install of windows ME since 11/2000. Well XP was pretty sluggish at first. I wouldn't be able to do much because it would take forever to open something up or if I was trying to install something, it wouldn't go fast. It got better later on.
Well the next day it didn't work so I figured maybe it was the hard drive or the motherboard. I went to a friends house and we put the hard drive into his computer and it recognized it just fine. We downloaded a diagnostic program from Maxtor and all the tests said my hard drive was fine. I put one of his old drives in my computer and it still couldn't recognize it or if it did, it would freeze before getting any further. We then decided it probably was the motherboard so I bought a Shuttle AK31 ver. 3.1 and a 512MB stick of DDR RAM by Dane-Elec. (Here's the description from Newegg.com where I got it: Dane-Elec DDR 512MB 64MBx64 PC-2100 RAM - OEM 64x64. 184-Pin. CL=2 Unbuffered,6-Layers. Requires DDR supported Motherboard - Lifetime Warranty) This ram would work with this motherboard? I installed the motherboard and it won't work. It won't post. I turn the power off by the switch in back because if I just use the front panel button, it won't power up at all. I took all my cards out and unplugged all my drives but still nothing. It won't even post. I don't know if the board is dead or the ram or if something else might be the problem. I also think it could be the power supply, but wouldn't it post if it was getting power and the fans were spinning?
Here's my set up:
AMD Athlon Thunderbird 800Mhz
Shuttle AK31 ver. 3.1 motherboard
512 MB Dane-Elec DDR RAM
Voodoo 5 5500 Video Card
Sound Blaster Live Value Sound card
Plextor 12/10/32 CD-RW
Pioneer 115 DVD-ROM
Maxtor 20.5 GB Hard Drive
Enlight Case w/ 300 Wt power supply.
Sony 3.5" Floppy drive
Netgear Network Card
The other motherboard and ram I have replaced are:
Abit KT7 motherboard
128 MB Crucial SD RAM
Can anyone help me or at least give me ways to test it. I have to return the 512 MB RAM w/in 7 days if it is bad.
If only I had another computer where I could test things. I can't even try other RAM because both sticks are different. Any help would be great and very very much appreciated. Thanks.
Jon
Here's my set up:
Pioneer 115 DVD-ROM
Jon
