- Sep 20, 2000
- 56
- 0
- 0
There's a flat panel display with a FPD connector. I believe it's MDR20 connection.
I think that there is 2 different versions of flat displays out there right now, DVI and FPD.
I need to get a graphic card to complement the monitor. Any suggestions? Any one can explain to me the intricacies of the different vdo cards?
Can I buy a GeForce MX with twinview and use an adapter with the DVI connection? Is there a MDR20pin adapter to DVI connector? What is the DVI connection called?
Can't seem to find a FDP card anywhere....or in stock. Don't even know if it's the right one when I see it. Is there a way to tell by looking at the connections the difference between DVI and FDP.
Please help...really confuse....why can't they just make a FDP with DB15!!!!!!!!!!!!!
Peace Out.
Peace Out.
