The big thing is that distributorless ignitons fire onboth the bang and the blow strokes 🙂 ( suck, press, bang, blow ) 🙂
That way, you only need 4 coils for a 8 cyl engine. The recharge rate is therefore higher ( and voltage delivered to the plugs ) then having a coil fire 8 times.
The coils are triggered from the crank. Some engines use an internal sensor stator ring on the crank, while most use a hall effect trigger on the snout of the crank.
