Just wondering.
Every now and again, the lights in my apartment flicker - sometimes, they flicker like crazy for up to half an hour at a time. It's been a lot better since switching to CFL and halogen lights - low voltage halogens are almost completely unaffected. However, standard incandescents can be really bad at times - and if you want to dim them, well, you make it twice as bad. In between times, however, the power is stable as a rock.
This is definitely a problem throughout the whole apartment block, as we've had a few discussions on our forums about it. Happens at any time, including late evening and weekends.
I lived elsewhere in the city a couple of years ago, and I happened to notice similar flickering then - but at that point I had CFLs mainly, rather than halogen - and the power wasn't as good anyway, as the voltage would sag noticeably with big loads (as it was out in the suburbs). In my new apartment, voltage doesn't budge much, even when switching on a 7 kW load (unless it's on the same circuit). [I estimate supply impedance at my service to be about 20 mOhm].
Having monitored the voltage over a few days, I think that the voltage fluctuations are within legal limits, so I'm not sure I've got a complaint. However, I'm just interested in what might be causing it. The fluctuations can be quite significant (repeated 4-5 V fluctuation in RMS voltage several times per second).
Example trace: flicker.jpg The three traces are max/mean/min cycle by cycle voltage. So you can see episodes where there is noticeable rapid fluctuation where the lines separate. This is only a mild example, but I can't find a severe example at the moment.
So, what sort of thing can cause such marked flickering? It's clearly not anything within the apartment building. Could it be something so big, that's it causes power fluctuations across the whole city? I have also recorded sudden drops in grid frequency when these fluctuations start - e.g. 0.1V flicker voltage, then suddenly 4 V flicker, simultaneous with a drop of 0.05 Hz in grid frequency. So this does lend some credibility to it being something huge.
Any ideas, among electrically oriented sleuths?
