- Dec 23, 2004
- 1,569
- 3
- 81
I'm looking at importing some stuff to use here in Japan. For example, a Bosch 1000w rotary hammer drill. Will the lower voltage have any real-world effect?
Wow 20% sounds like a lot. A reliable Transformer capable of running 1000+ Watts is pretty expensive, and may be a pain the ass.
Running at 100V/50Hz would probably be better than 100V/60Hz anyway, since you should be reducing the voltage to an induction motor as you decrease frequency to keep the flux density the same.What Dave has said is correct. The amount of real power that can be delivered to a load goes up/down as the square of the voltage. On that basis, a voltage drop from 120 volts to 100 volts lowers the delivered power by 30%.
Yes, it's true that the voltage you actually get at a socket can vary over a range from 100 - 120 volts; it's (mostly) affected by how much demand is being placed on the feeder that you and your neighbors are sharing. The higher the loads, the higher the currents, and the greater the voltage drop from what's at the substation. There are control schemes for tap changers and shunt capacitors that help keep voltages reasonably close to 115 volt target, but it's inexact. People nearer the substation will generally have higher voltages than those connected towards the ends of a feeder.
I'm guessing that the same will be true of voltages in Japan; 100 volts will be the maximum but actual voltage will be less than 100 volts.
Besides this theoretical limit on power delivery, lower voltages also cause problems for induction motors (like those used in power tools). Low voltages increase current draws and therefore cause more heating, and the motor is easier to lock up (i.e. stop turning) under load. You can also run into these same problems when using long and/or small extension cords.
I don't know what part of Japan you are living in, but you should also double check the 60 Hz. The (southern) western parts of Japan are 60 Hz, but the (northern) eastern parts of Japan are 50 Hz. A motor designed for 60 Hz will run at 5/6 speed on 50 Hz (and see a little more heating too).
https://en.wikipedia.org/wiki/Electricity_sector_in_Japan#/media/File:Power_Grid_of_Japan.svg
If I were you, I'd see if anyone else has tried using US market tools and what their experience has been.
Good luck!
Mr teal, I just saw your post, I had forgotten about the grounding issue. So appliances made for Japan will have special stuff to make up for the lack of a ground plug?
