Can aluminum siding interfere with HDTV OTA signal?
ScottFern
3,629
My house has full aluminum siding all around it. Now I have been considering an HDTV card for my computer, and I was reading that it might not be worth it if you have aluminum sidings?
Also, does anyone have T-Mobile/Cingular and does your reception suck inside houses with aluminum siding? Mine is pretty bad. :(
On a good note, I think we are moving soon!
Gibson486
18,378
Well, aluminum does act as a sheild for most radio signals.... but i don't think it would really effect so badly that you will loose your signal entirely.
edit...wait...you are talking about HDTV....i thought you were referring to your cell phone....anyways....from what I know, HDTV is recieved through coaxil cable...how would the surrounding of your house affect that? Anyone?
electricJ
386
He might be talking about receiving digital channels via OTA signals.
ScottFern
3,629
Yes, I was referring to Over The Air HDTV not the coxail.
Anyway, I was also asking about cell phone reception as well. I just wanted to know in general if aluminum siding interferes with reception of cell phones, HDTV OTA signals.
icelazer
323
Not sure on this one, just a note though, if you're going to attempt OTA HDTV, you need to pickup either a "Silver Sensor" antenna (very small, made by some overseas manufacturer) or a helical antenna for better reception.
