Originally posted by: quakefiend420
cue Yo in 3...2...1...
I don't have to answer this if I don't want to.
lol, yeah he's pretty good with anything audio related
awww fvck it... yeah, just set the output to AC3 rather than PCM and it should pass the stream.
I don't remember trying it with a DTS track, but I know DD works for sure.
Sure you do. If you don't then it'll bother you for the rest of your life. You'll have nightmares about not helping someone with their audio problem. It will haunt you for all of time. You'll wake up in the middle of the night screaming and pouring sweat.
dude you are the man, I'm going to give that a shot
and since I'm asking questions is there a way to somehow identify what type of sound date (dolby, etc..) is encoded in a video clip
Not sure on testing what kind of sound it has on clips. What's your source material?
hmm how do I set the output? Is that on the receiver end or on the PC?
I have lots of different avi and mpeg clips, I think most of them are encoded with XVID.
Did you get some drivers from via arena?
There should be a control program in your system tray area (aww crap, what do you call it? The icons in the lower right... I'm no good at windows terminology)
I see
A lot of those tend to be just stereo sound I think. I've seen several DD encoded ones, nothing DTS though that I've seen.
http://www.viaarena.com/default.aspx?PageID=420&OSID=1&CatID=1010&SubCatID=107
Thanks again, I'm downloading the driver as we speak (or type is probably the better word)
You'll have much more control over what's going on with that program.
It's pretty basic but it does everything you'll need it to.
Set it to standard 2.0 and then you can mess around with checkboxes and stuff.
I've heard that the newest ones might not be the best. If something isn't quite working right you may want to look around and see if you can get an older version of them (but newer than what comes on your cd)
Uhhh.... how about uninstall the current drivers, restart, and then install the via arena drivers you downloaded when it asks where the drivers are?
Now, if you'll excuse me.... I have to see if I'm going to get told to go eat some ice cream or not :evil:
