Can a network card degrade internet speed?
Vich
2,849
I have some generic no name ethernet card and i was wondering if i would get faster speeds (or the same) if i got a 3com ethernet card which is about $40.
So if i get a leading brand ethernet card will my ping to gateway lessen? To gateway i ping 10-13.
And in general will internet downloads be quicker?
Any comments?
oblivion2888
Banned
Mar 3, 2000
2,468
no, cable modems or dsl cannot strain a NIC......on the other hand.....if you were transferring a large 1 gig file between two comps at 100 mbps, then NIC quality could matter
Scope
1,324
Look at it this way you can get a linksys, netgear or dlink 10/100 card from onvia for $22-26[Can] so this isn't really an issue. To answer your question most isp's won't outperform a 10baset nic but for a home network and transfering big files an 10/100 card makes a huge difference. As for the card being generic or branded that usually has to do with hardware in/compatibility and not it's performance. Almost all 10/100 nic's I've used are all within 5% of each other.
Scope!
