Can a cigarette light a gasoline fire?
James Bond
6,023
In movies, they always have a badass dude toss a cigarette into a stream of gasoline to ignite a large fire. (Usual Suspects, etc).
One of my friends told me that cigarettes don't generate enough heat to ignite gasoline, and assured me that he had personally tested it.
Does anyone know if that is true?
coolred
4,911
I believe they tried that on mythbusters, and I don't think it was able to ignite the gasoline
Amused
57,474
19,970
No. A lit cigarette cannot light gasoline on fire.
I was shown this way back as a teen when I worked at a gas station. The manager filled a dixie cup with gas, and doused his cigarette in it.
That freaked me out. :p
FoBoT
63,084
15
fobot.com
mythbusters did this as part of the exploding toilet myth
it think they found that it wasn't reliable, they had to use a match/open flame
but i don't recommend you rely on this for your own safety
Midlander
2,456
I have seen someone put out a cigarette by dunking it in gasoline. He did wait for a bit after he had taken a puff before extinguishing it, so I don't know if that amount of cooling made a difference.
oCxTiTaN
453
gasoline itself isn't flammable, it's the fumes so if you toss a cigarette into a bucket or puddle of gasoline it won't have the chance to actually light the fumes but instead get put out by the liquid gas...
Amused
57,474
19,970
Originally posted by: compnovice
Try putting one in your gas tank :p
IMO, it will....
Your opinion would be wrong. The cherry of a cigarette is not hot enough to ignite gasoline.
Leros
21,867
7
I would think a cigarette might be able to light the fumes in a can, but not a liquid filled container.
tweakmm
18,436
4
Originally posted by: Eghck
only if you're having a freak gasoline fight with 3 of your buddies...
You know, there's more to life than being really really really good looking.
foghorn67
11,883
63
It's the fumes. I know people that aren't careful with fuel tanks that have been empty for months....Kablamo!
Minerva
2,134
25
Gasoline has a sub 500°F ignition point. In the presence of sufficient oxygen and gasoline vapors, ignition can occur with a lit cigarette. When an idiot tosses one out their window at night and it flies into the road sending sparks everywhere those sparks could easily light gas that was poured on the pavement recently.
Fortunately things have to come together to have this happen. There's other ways to make sure the gas will blow if you must have it go off.
artikk
4,172
Originally posted by: illusion88
Originally posted by: Mwilding
if you get enough fumes, yes
but this isn't about fumes, this is about liquid gas
a gas isn't a liquid and vice versa. You were trying to specify that a cigarette wouldn't light gasoline in its liquid form.
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
It cannot ignite liquid gasoline.
It can, under the right circumstances, ignite the vapors that form just above a puddle of gasoline if there's not enough air circulation to disperse those vapors.
ZV
BooGiMaN
7,955
i think mythbusters also showed that you can not blow up a car by shooting bullets at its gas tank
Ika
14,264
Actually, I believe that was with a lighter.
But LOL anyway! I love that movie.
TheChort
4,203
I think the difference between this and the OP's example is the toilet is a pool of gasoline, and the cigarette dips into the pool, where there is no oxygen. But in the OP, the cig would rest on top of the stream of gasoline.
Just an observation ;)
