I know, this sounds like a stupid question but it is something that i need to know. To make a long story short, i plugged in AC Ryan 120mm Blackfire fan's 3 pin connector into the mobo's SYS FAN header and unplugged the molex. Before it was running plugged into the 4 pin molex via an adaptor. Plugged in & turned on the PC, all the fans including this one are spining but system wont boot. The monitor would turn on and then turn off, thats it. So i plugged the fan back into the 4 pin molex & into the PSU and system booted fine. So is possible to run a case fan without the 4 pin molex plugged in and by just having fan's 3 pin connector plugged into mobo? If yes, why cant i do it? Can anyone answer this?
