gotensan01
I know the 9700pro uses 4 hold down screws for the hsf. I am looking at buying a water block that fits 9000 and 9700 pro cards. I was wondering if the hole to hole distance diagonally across the 9700pro hsf mount is the same as the hole to hole distance on the 9800 pro.
This is the water block I was looking at getting. If anyone knows anything about this subject, I would appreciate the feedback. Or if anyone owns a 9700pro card and is willing to measure the hole to hole distance diagonally across the hsf, that'd be great. Thanks guys.
