imported_Mike
Want to get a filter for my digi cam, A regular filter costs me $30(retail) while the polarizing costs $70(retail). Is the polarizing worth the $40 difference?
Originally posted by: CheapArse
Yes, the "reg" filter is the UV filter. Can I assume the polarizing filter filters UV & helps against reflective surfaces?
Originally posted by: Viper GTS
What do you mean by a "filter" it should have some purpose, you don't add additional glass for sh!ts & giggles.
ok, the $30 filter is a "neutral density filter", and the polarizing filter talks about reflective surfaces which has been brought up already. But it turns out its only 37mm & I would have to get the 52mm adapter just to fit it on. ~$100 total....1/4 of the cost of the camera.
Most of the amateur photographers I know use a UV filter as a simple lens protector. Optically, it's pretty unintrusive.
Neutral density filters help to regulate the spot metering of your camera for shots with great varience in lighting (like bright skys and shadows).
Example : http://www.aaacamera.com/neutral_density_filter.html
ah, ok....I need an AIW filter 😛 So bust out the neutral density for bright/dark outdoors. Polarize for reflective surfaces.
Yup.
Another cool filter is a enhancing filter. Basically enhances the contrast in colors to provide a more dramatic picture.
http://www.aaacamera.com/enhancing_filter.html
Also, have you ever used a polarizing filter before?
