camera people... minimum shutter speed for non-tripod (camera in hand) use?
pennylane
6,077
At what shutter speed do you consider it safe to hold a camera in your hand and get nice non-blurry pics?
halik
25,696
if youre good you can do it slower. Hold you breath and push your elbows in your stomach
illusion88
13,164
Originally posted by: NutBucket
1/60.
1/60 is your best bet. 1/40 if you can lean on something, or have a really steady arm. Most of my cameras are all metal and wiegh a ton, so my arm isnt as steady as it could be.
NutBucket
27,154
635
1/60.
I think I have more trouble with my S200 then I do with my EOS.
Crimson
Banned
Oct 11, 1999
3,809
Use the inverse rule... if you have a 50mm lens, assume 1/50th of a second.. Using a telephoto? 200mm would require around 1/200th...
NutBucket
27,154
635
Hmm, never heard this rule. I guess I haven't run into that situation using my telephoto before.
