Calling you electronic genuises - fun project
dmurray14
I'm trying to replace an hardwired irrigation network (30 valves or so) with a completely wireless one. Going wired just doesn't work well - wires get chewed up, cut up, or just degrade, and it's a major undertaking to replace them. So, I'd like to do something with wireless. So far what I'm thinking is a system with a rechargable 12v battery and solar panel at each location, along with a wireless recevier. When the receiver gets a signal, it will power the valve open (usually running for ~2 hrs). I just can't figure out what to use for the wireless portion - does anyone know of a wireless transmitter/receiver cabaple of transmitting to 30 different devices individually? Any other ideas or input is appreciated!
Thanks,
Dan
We have the technology... We can build it... But at what cost...
Wireless data transmitters and receivers are available, but at a price. Expect to spend at least $100 per unit on just that. For the radio portion, you will need to get a generic radio modem, and program a processor to decode the data. Here are some manufacturers, but not necessarily the cheapest ones:
http://www.data-linc.com/plantlinc/
http://www.radiodata.co.uk/Products/rdt-data.htm
http://www.elprotech.com/elpro/405.htm
http://www.intuicom.com/
Most sprinklers operate off of a solenoid. Power will be your big problem. It will take some battery juice to hold the solenoid open.
Expect to roll-your-own here. You will need per sprinker or zone:
(note that my prices are ball-park estimates)
1) Wireless receiver - $100
2) Large rechargable battery. Probaby a gell-cell would be the best - $20
3) Microprocessor to receive and decode the wireless data. A "Pic" or "Basic Stamp" should be OK - $40
4) Solar Cell, fairly large to recharge the battery - $40
5) Solenoid valve - $10 (you may already have these).
6) Some sort of plastic or metal housing to protect this stuff from the weather - $20.
So far, we are up to $220 per unit. So the grand total will be $6,600. This is assuming that you can find a radio receiver for $100. You will also need wire, perf-board, caps, resistors, etc.
Have fun!
thanks for the reply. I was hoping for something a -bit- more turnkey, but if I have to improvise, I will. The receviers are the big deal now - I'll have to see what else I can find out...
Thanks again,
Dan
He's right. I've looked into this before and it's crazy expensive for a hobby / private project.
A PIC is like $3, not $40.
I'd probably rig it with remote-control car servos somehow.. they're cheaper.
I guess servo is wrong word.. i thought RC cars had servo motor + reciever one piece?
must be seperate.
I suppose you could make your own AM recievers, spaced out 5KHz or something, and have the PIC make sense of whatever you're transmitting via an ADC deal
I PIC is like $3 if you buy them in huge lots (thousands) from a retailer, for a handfull, you'll pay much more.
ok, $5...7 or so
hmm...this could get interesting
I feel like there must be a more simple way than using a wireless modem....
and it would be pretty cool to figure something out with Wifi- but probaly even more expensive
must be seperate.
No, they're separate.
Have fun!
By the way, $220 per unit is not a problem at all. We could probably do around $500/unit for just the receiving equipment. Does this open up the creative damper?
Dan
