calling all widescreen monitor users (2nd post)
Supernaut
50
Hello
I own 2 sgi 1600sw LCDs. Max resolution on them is 1600x1024 but I cannot get this resolution with the nvidia references drivers. This resolution works correctly with the matrox g400, elsa geforce3 drivers and the geforce3 drivers on the WinXP cd but thats it. I was wondering if someone could shed some light on the subject. Also, I user powerstrip and suggested by sgi but that did not work. SGI also did say that the nvidia reference drivers would not work, only certain older versions. Can anyone offer any help :)
thx in advance
imgod2u
993
It should autodetect the monitor, if not, try installing whatever driver cd that came with the monitor. Of that I'm aware, you need to use the VGA in order to get resolutions of 1600x1024. Also, is that monitor capable of 1600x1024?
Supernaut
50
its not a problem with selecting the resolution. The correct resolution is there. The sgis maximum resolution is 1600x1024. What happens when I set the resolution is that the image is squished. There is an "alternate" mode that stretches the image accross the screen but the image is messed up. I am guessing that the video card does not communicate with the monitor correctly. So all the pixels are being displayed just at a 1280x1024 resolution. The image is just distorted horizontally. I was able to use this resolution with other video drivers, its just the nvidia reference drivers that dont work. Since elsa is out of business, I cannot use their drivers anymore.
Supernaut
50
its me again :)
thx for the good advice but when I read over the article I noticed he used older drivers :(.
12.41. I am going 2 try n use leadteks drivers, hey y not right :).
thx for the great link though :) if u find nething else please post it I appreciate it greatly
BUMP BUMP
Supernaut
50
I cant believe it.
After I installed the leadtek drivers n removed em, I installed the newest reference drivers n they worked!
and that dave guy emailed me back in like 10 mins!
thx again
