Calling a stored procedure from T-SQL
Bulldog13
I have an insert trigger on TABLE_A. On insert into TABLE_A, it takes Inserted.SSN and Inserted.PK and puts them into a TABLE_B.
declare @SSN varchar(9);
INSERT INTO [dbo].[TABLE_B]
(SSN, ID)
SELECT INSERTED.SSN,
INSERTED.PK
From INSERTED
select @SSN = Inserted.ssn from inserted
I want to add onto this trigger so that I can run a stored procedure on the Inserted.SSN and retrieve the results.
exec dbo.spGet_Member_POC @SSN
[what t-sql magic here to capture the result ?]
