I have a computer that will be going on about a year and a half old soon. Specs are as follows:
Intel Q6600
Abit IP35 Pro
MSI 8800GTS OC 640MB
2gb OCZ Reaper DDR2 800
X-Clio 650W PSU
For about the past 6 months I have been having gaming troubles. When I play graphics intensive games (Crysis, Call of Duty 4, Fallout 3), the games will lock up and kick me out to my desktop. Since it's happened very similar in all 3 games, I've ruled out the possibility of it being a bad install. I've updated my drivers and done the usual re-seating and whatnot. I've also swapped the memory (but it was a 4gb kit to begin with, so it's all the same batch). Basically, I think the problem is with the GPU either overheating or failing some other way. It seems like it's idling really high at about 64C. Cooling wasn't a problem when I first built the machine, and all the fans are still working, but that number just seems high.
What do you guys think? Is it the video card causing the problems? Or should I try different memory again?
Thanks
Dan
Intel Q6600
Abit IP35 Pro
X-Clio 650W PSU
Thanks
Dan
