California water rationing:50 gallons per person per day or $500 fine
JEDIYoda
33,986
3,320
even if you round down to 5 GMP for a non low use shower head thats still a 10 min shower and you have used all your water for the day
pretty sure the rain shower head we have is north of 10 GPM, its like a garden hose, its amazing
BS...you don`t need 10 minutes in the shower with it running.....
Hell......wet your body...lather up and rinse........
I lived in India when we had water rationing in Madras. Trust me I can live on 50 gal a week if need be. 50 gal / a day, not a problem!
iGas
6,240
hm...an average showerhead uses 7-10GPM, that means I must blow through an average of 200 gallons a day on showers alone O_O
Where the hell did you pull that number?
At 7 f/s, 1/2 copper = 5 GPM, and 1/2 PEX = 3 GPM
However, realistic pressure at your shower head with open pipe after pressure/friction lost through pipe runs, elbows, and PRV at best would be somewhere around 4-5 f/s (5 f/s with 1/2 copper yiedd 3.6 GPM, much less with PEX. And, Uniform Plumbing Code indicated that shower head calculation is 2 fixture units or 2 GPM).
Common Household Pipe Types: Maximum Flow at 7 f/s
http://www.engineeringtoolbox.com/Water-Supply-Fixture-Units-d_1073.html
Californian average water usage per capital is 147-379 gallons daily pending area.
[add]
That said, IMHO Californian going to get f___ed no matter what unless by some miracle they get steady rain that replenish reservoirs ASAP.
iGas
6,240
The link I looked at said conventional =7-10gpm, efficient = 2-4gpm
http://www.wsscwater.com/home/jsp/content/water-usagechart.faces
The day I cannot take 15 minute hot showers is the day I start planning my move out of CA.
I highly doubt this bad boy only outputs 2.5GPM, if it does then that is freaking amazing:
It is highly likely that your shower head output is 2.5 GPM or less. And, if it is a low flow then it is as low as 1.5 or 1.6 GPM..
Since 1992, federal regulations have required that manufacturers produce shower heads with maximum gallons per minute (gpm) ratings of 2.5 gpm.
http://www.appropedia.org/1.6_GPM_or_less_low-flow_shower_heads
iGas
6,240
Highly unlikely that your rain shower head water deliver is greater than 2.5 GPM, because the US Environmental Protection Agency, American Water Works Association, American Society for Testing and Materials, etc... would come down on the company that sells such a shower head so hard that they wouldn't know what hit them.
Anubis
78,712
427
tbqhwy.com
And I grew up in Minnesota where water isn't a problem except when there's too much of it. My point is that if, you never leave your basement, you tend to think water comes out of faucets. Where do the people who live in places with drought and water shortages, think the water is going to come from? It's just plain silly to live without giving it any thought.
in LA they steal it from Mono County
Texashiker
18,811
197
actually you have no business being in the shower for more than a few minutes.
What someone does in the privacy of their home is none of your business.
As for the opening post, people are only part of the problem. Cities in california have created an artificial landscape. Do we think beverly hills is going to let all those palm trees die?
Didn't lady gaga recently catch some flak for emptying an Olympic size swimming pool?
HOAs / POAs still require people to water their lawn or get fined.
As long as people have theirs, screw everyone else.
Chaotic42
33,932
1,113
When will they get to the point where they stop farming in the desert with water they don't have?
Jaskalas
33,895
7,918
They've had water available for the past century, but a combination of drought, eco-kooks fighting the creation of reservoirs, and a surging (illegal) population means there's less and less available.
zephyrprime
7,512
I live in minnesota and my water bill was really high one time. I called to complain and I found out that the average bill was about 100/gallons a day per person. I thought this was crazy high however, I then calculated all my water usage and found that indeed, my water level was fricken high.
Where did all the water go? Running water from brushing teeth. Running water while washing dishes. Toilet flushes. Showers.
With 50 gallons a day, you will need to switch from showers to baths. Also you need to watch your toilet usage. Worth it to install dual flush systems with such stringent requirements. Swith to front load washer. Or you could just move out of the fricken desert.
CPA
30,322
4
actually you have no business being in the shower for more than a few minutes.....also where we live the toilets and shower fixtures have to be low flow..... 7 to 10 gpm seems really like a lot of water...
lol, i guess we will need shower police next. Thank you for telling us what we need and what we don't need, what we should do and what we shouldn't do, comrade.
zephyrprime
7,512
[add]
Such calculations are unnecessary. The government limits showerheads to 2.5gpm. Really old units can run 5.5 gpm.
JeepinEd
869
63
Here are a couple of interesting links regarding water usage.
http://www.sanfranciscobay.sierraclub.org/yodeler/html/2010/05/article5.htm
According to this article, 80 percent of the water used, goes to farming, leaving 20 percent for residential. If this is correct, even if we meet the goal of reducing residential use by 20%, it really would only save 4% of total water usage (not including water that is diverted for natural habitats).
http://californiawaterblog.com/2011/05/05/water—who-uses-how-much/
Ns1
55,418
1,595
Even @ 3gpm, 30 minutes of showers a day divided by however many people is a cool 90 gallons.
I'd probably get a membership at the local gym to tax their hot water or something.
Texashiker
18,811
197
Watering the lawn takes a lot more than taking a shower.
There was an article a couple of months ago where a POA/HOA sent a warning letter to a couple for their brown grass.
The couple received a letter from some California state water agency asking people to conserve water, so the couple stopped watering their grass. Grass turned brown, hoa threatened to fine the couple several hundred dollars.
EDIT
Found the article,
http://www.foxnews.com/us/2014/07/1...brown-lawn-after-complying-with-water-saving/
We would not want grass to turn brown in during a drought, right?
DrPizza
Mar 5, 2001
49,601
166
111
www.slatebrookfarm.com
Perhaps you are not aware of cultural differences between India and the United States. In the United States, you're considered dirty and stinky if you don't shower every day.
Sonikku
15,745
4,563
Tell it to George Carlin.
Attic
4,282
50 gallons isn't much water per person. Remember, flushing the toilet a few times a day per person, a shower per day, washing dishes, washing clothes. Even little things like leaving the water running while brushing teeth adds up to a few gallons. And you'd better hope that you don't have a slowly leaking toilet. 50 gallons per day is well below average in this country.
Anyhow, until there's a reputable site...
50 gallons is too low IMO. I'd rather it be alon lines of 75gallon limit per day, with larger fines above it. Most of the water waste is not coming from typical households,.. it's coming from large homes with large yards and it's coming from golf courses and other businesses that use large amounts of water.
The 50gallon limit would hit poor/middle class in order to serve the well to do and privileged who could use well above that amount and happily pay a $500 fine.
Don't hit the poor/middle class for water waste that is not equally distributed amongst the populace. $500 fine for the well to do, even if once per month, they don't give a shit, $500 fine for the rest of us, particularly if monthly, is a big deal.
But yes, none of this is happening.
Mark R
16
Round here, if there is an official drought order, then you aren't permitted to water land (unless a farmer, or you have some other exemption, or your own water source).
A number of city or regional governments regularly take aerial photos, to look for residences with green lawns. If you've got a green lawn, you get a summons in the mail, and have to explain yourself to the judge.
Leymenaide
749
364
There are some major cities in California that homes do not have meters. They will have a difficult time with enforcement.
Californian is to Water as
Democrat is to entitlement.
