Calculus Help! Edited new problem
Scrooge2
856
find function g(x) with dg/dx = [Ln(x)]/x
*Edit*
Find tan (arcsin (x))
what the heck does that mean? It didn't ask for the derivative...
Stojakapimp
2,184
use substitution.
Make u = Ln(x), so du = 1/x. Now you can just replace the 1/x part with du
GiLtY
1,487
Integrate the thing, you'll have a constant term, C. Unless you know the initial conditions you won't be able to find the exact solution.
Easiest way is to use u/du substitution, let u equal to LN(x)
--GiLtY
Scrooge2
856
can anyone solve it out for me? I'm not sure if i got it right or not, but I got [ln^2x]/2+c
I just haven't done this in a while...
dighn
22,820
4
verifying an integral is easy, just differentiate it. looks right to me.
Scrooge2
856
Yeah, I think I've got it. Thanks all. Like I said I did this last year and don't remember much of it. I'm transfering to another college and these ingrates don't want to take my calc I + II credits because they gave me some dumb spiel about their college's math department is top notch. They are a state college and wont take calc credits from a private engineering university but will take calc credits from the local community college. How dumb is that?
Anyways I'm trying to take this test so I can skip at leat calc I. It's slowly starting to return to me THANKS! :D
WhiteKnight
2,952
Maybe that's some sort of typo? I don't understand what they are asking for either. Perhaps you are just supposed to simplify it?
Syringer
19,333
That's a real simple problem. Just draw your triangle..since it's asking for sin(x)..
Draw a right triangle, have theta be one of the angles, and since it's sin..x represents the side opposite to the angle, and since x = x/1, 1 represents the hypotenuse, and the adjacent side would then equal sqrt(1-x^2)..through Pythagorean's theorem.
Then, all you have to take is the tangent of that, which means y/x, or x / sqrt(1-x^2)
Syringer
19,333
Okay, I drew up a picture here..
http://pichosting.pcthike.com/albun15/untitled
That's your triangle..that's what arcsin(x/1) looks like. Since it's sine, you know that the angle theta is opposite over hyptonuse, or in this case, x/1..so the side opposite to theta is x, and the hypotonuse is 1.
From there, we can derive the adjacent side as being sqrt(1-x^2) through Pythagorean's theorem.
Then finally, since we want to find tan(arcsin(x/1)), we take the tangent of the triangle..which is opposite over adjacent..or in this case, x/sqrt(1-x^2)
Hope that was clearer :)
