Dont think you need calculus. The document you desire is "Thorndike Encyclopedia of Banking and Financial Tables". Besides actual tables, it has the definition of terms and the various banking/financial formulas along with sample calculations. You can check your calculations often using the tables in the encyclopedia.
This book (normally $195 new) should be contained in the reference section of your local library.
