In some reading materials for teachers online, I recall a demonstration of mixing equal parts water and rubbing alcohol into a graduated cylinder to demonstrate that the volume do not add up, because alcohol and water interacts on molecular level and shrinks in volume.
100ml of alcohol + 100ml of water mixed and stirred yields something like 190ml of water/alcohol solution.
http://answers.yahoo.com/question/index?qid=20080124082949AAGrjJ5
In the beverage industry, the expression used is the percent absolute alcohol per volume, or ABV.
So, if one was to take 500ml of pure alcohol, 500ml of water and blend the two they'll shrink. Since we know the amount of absolute alcohol that was in it, would the new solution be higher than 50%, because it is 500ml alcohol/970ml =51.5% or would it be 500/(500+500)=50% based on original volumes?
So to yield a liter of 50.0% alcohol=by-volume solution, does one have to add 500ml of pure alcohol and add 500ml, THEN add water until you hit the 1000ml line on the volumetric flask?
