calc problem that really has nothing to do with calc :)
BigToque
11,700
I'm trying to find a limit:
This is the question (I saved it as am image because it's easier to see the question that way).
I understand I'm supposed to divide both the numerator and the denominator by the largest power of x in the denominator, but I'm not sure what that is (the square root is throwing me off).
Would it be just X? (like X^1)
ClueLis
2,269
Originally posted by: MaxFusion16
l'hopital
It doesn't qualify for using L'Hopital's rule, as you have infinity-infinity on the bottom, which wouldn't work.
DrPizza
Mar 5, 2001
49,601
167
111
www.slatebrookfarm.com
quick explanation for you though:
numerator can be approximated by x for really large (albeit negative) values of x.
(when you're talking about -100000000000 and -100000000001, the 1 doesn't make much of a difference.)
the square root part of the denominator will approach |x| (it'll be positive since you're squaring x and then taking the square root) And, -x is of course |x| since x is negative. Thus the denominator will be approximately twice the size of the numerator (and positive) while the numerator will be negative.
So, -1/2
Pokey007
431
So, -1/2
yup :)
BigToque
11,700
I still don't understand the steps that I am supposed to follow.
I know that I need to divide the numerator and denominator by the largest power of x in the denominator, I just dont know how to get (or find out) what the largest power of x is.
My problem isnt the "calculus" part, it's the algebra that's my problem. I never took pre-calc.
