How did you get 2x + 6?Originally posted by: dighn
no i use aim sorry
dy/dx does give you enough to work with
dy/dx = 2x + 6 = 4, easily solve for x
then sub x into original equation for y
Haven't learned that either.Originally posted by: da loser
do you know what a derivative is?
Well, I can find the tangent of any point on the graph of x^2 + 6x + 9, but my problem is I can't find the points that correspond to a slope of 4 on that graph.Originally posted by: Ionizer86
Howard, are you starting afresh? Do you know how to take the deriv of the original equation y=x^2 + 6x + 9 ? The deriv comes from there.
If you need to start with the Derivative by definition (4 step), see your book or see here. Basically, you're taking the delta y over delta x when the deltas are extremely small, hence the added on h approaching zero.
If you want the shortcut: you're basically taking the x^2, multiplying the whole thing by a coefficient of the power (2) and dropping the power by 1 from 2 to 1. On the other term, you have 6x, so you multiply by the power of 1 then reduce the x^1 power to x^0, leaving your product as 6.
WTF do your own homework
j/k
slope = dy/dx
then you just need the point of tangency which you can solve by solving dy/dx = 4, then subbing x into original euqstion for y
then sub x,y into your line eq and solve for b
😕Originally posted by: Ionizer86
