Calc 1 Help
cyberfuzz
427
i really dont see how this has to do with what we are doing currently in calc, but the instructor tossed this problem in for the hell of it.
Area: A rancher has 200 feet of fencing with which to enclose two adjacent rectangular corrals. What dimentions should be used so that the enclosure area will be maximum.
________
l.......l.........l
l.......l.........l Y
l___l____l
X .........X
Dotted lines are put there to make picture work. how do i show this as an equation?
BigJ
21,330
I'd imagine you setup an equation, get it in the form of y =, take the derivative, and find the absolute maximum.
MrDudeMan
15,069
94
ah the good old days of calculus 1. find a function, take the derivative, set it equal to 0 and solve.
MrChad
13,507
f(x) = 2xy
200 = 4x + 3y
Combine equations.
Find max, find values for x and y.
Wheatmaster
3,882
make formula, take derviative and set the function equal to zero, get your x, plug back into original formula, get dimensions. it's called optimization.
Goosemaster
48,775
"...and by the moonlight, as our luscious bodies caressed each other, we proceeded to integrate...."
hmmm....
Aug 10, 2001
10,420
area=2xy
perimeter=4x+2y=200
substitute
[100y-y^2]'=100-2y=0; y=50
[200x-4x^2]'=200-8x; x=25
EDIT: Errr...that's not correct. I forgot the fence between the two corrals. :eek:
