- Feb 14, 2004
- 52,104
- 7,495
- 136
This is probably a dumb question, but I don't know what the answer is. I've built a couple engineering computers recently where they needed a CAD card for dual monitors (say a Quadro FX 5800), plus a couple extra monitors for email & such. I slapped in some cheap cards like an 8400GS for the extra monitors. How does CAD rendering work across the monitors?
Does the application pull from the CAD GPU no matter which monitor it's on? Or does it default to the CAD card-connected LCD's? If you drag it halfway across a CAD-connected monitor to a cheap card-connected monitor, how does that work? I know with the newer laptops that have the iGPU's, you can toggle which applications actually use the dedicated GPU so you don't burn up the battery life. On a desktop without that setup, how does it handle it under Windows typically?
